NI TestStand
side affect of launch report viewer
it appears that when launch report viewer is invoked, it creates a tempresults.htm file in the current report directory and does not clean up after itself. subsequent calls create tempresults_00002.htm etc files presumably becuase it is following the report options that I have set. Is there any way to not clutter the report directory with these temp files?
Stu
(3,061 Views)
Stu -
I believe that these temp report files will be cleaned up with the engine is shutdown. This is done because TestStand does not know when the external report viewer is done with the file.
TestStand places the temp report in the same directory as the report directory because TestStand assumes that the report may require some additional support files relative to the report directory.
Scott
Scott Richardson
https://testeract.com
(3,061 Views)
