To rjmiller -
A TS container is an object which can have references to other objects, so there is not way to determine a size because it is not continuous in memory.
If the object is a type and structure packing settings for the type are specified, TestStand knows how to pack and unpack the object data into a struct parameter of that type.
I guess the struct passing settings dialog box could display what it thinks that the corresponding size is for the struct, but it currently does not do this.
Scott Richardson (NI)
Scott Richardson
https://testeract.com
