NI TestStand
slow loop speed with USB 6009 DAQ
hello, i'm very new  working with Lab view and using an USB 6009. I have the problem of very slow loop speeds when aquising data in a while loop  (the loop is running only about 300 times a second) How can I get this faster? I want to count the signals (0 Volt, 5 Volt) of an linear encoder with the analoginputs of  the device (the USB 6009 has only one counter input so I can not get the direction of motionwith only one) Do you have any good ideas how I can manage this ?
Thank you very much for your help!
(2,949 Views)
You would get a better respond if you re-post this to the LabVIEW forum or if it hardware one of the Hardware related forums.
This is the TestStand forum.
Regards
Ray Farmer
Regards
Ray Farmer
(2,946 Views)
