NI TestStand
source control error labview
I have LabVIEW 8.0.1 on my machine and I recently installed and then removed perforce although SCC was never configured. I've been getting an error when labview starts now saying that source control could not be found and to go to options --> source control in labview to configure, which I did to <none>. But still the error occurs. Any help?
kph
(3,896 Views)
It probably would be best to direct this at the LabVIEW forum.
What is the actual error you are getting?
Maybe you could try removing the labVIEW.ini file so that when you launch labview the defaults are setup again.
Or there could be something in the registry setting for labview.
Regards
Ray Farmer
Regards
Ray Farmer
(3,886 Views)
Thanks Ray I realized my mistake too late and unfortunately I couldn't figure out a way to send it over to the labview forum or delete it. Those would be nice features to add to this board in my opinion.
kph
(3,876 Views)
while browsing in the labview forum I spotted your other messages. Glad you got the problem sorted.
Regards
Ray Farmer
Regards
Ray Farmer
(3,872 Views)
