NI TestStand
station globals enum type
hi mrbean,
I've attached the corrected vi (ver 8.0). I had to delete the space, so no optical illusion.
Regards
Ray Farmer
Regards
Ray Farmer
Message 21 of 25
(1,402 Views)
I see the space in the error out 'Explanation' field.  However, I don't see this space in any of my code.  I opened your VI, but it's only a front panel.  It doesn't allow me to view properties, though, so I can't tell exactly what you changed.
Message 22 of 25
(1,389 Views)
Its in the lookup strings for the GetValString nodes, left of your Loop.
I will resend the VI attachment later, can you confirm which labview version you are using.
Regards
Ray Farmer
Regards
Ray Farmer
Message 23 of 25
(1,387 Views)
I'm using TestStand 3.5 and LabView 8.  Thanks.
Message 24 of 25
(1,385 Views)
Just remember the VI got a custom window appearance settings in the VI properties and it runs when launched, just click on the Continue button, then you will be able to get the diagram.
Regards
Ray Farmer
Regards
Ray Farmer
Message 25 of 25
(1,375 Views)
