NI TestStand
step_description unknown variable error in built operator interface
I'm getting the following error when I execute a seq. from a built LabVIEW operator interface:
Error evaluating expression
Unknown variable or property name 'STEP_DESCRIPTION'.
Error accessing item 'STEP_DESCRIPTION'.
Some searching is leading me to an issue with the localization languages files? Not sure what exactly.
Message Edited by Michael Aivaliotis on 11-06-2007 01:09 PM
Michael Aivaliotis
VI Shots LLC
(3,230 Views)
Here is a guess: try right clicking on the step list and select a different step list configuration. If the problem goes away, then your current step list configuration has a column specified by expression and there is a problem with the expression.
Message Edited by James Grey on 11-06-2007 03:14 PM
(3,225 Views)
Are you referring to the SequenceView Control Properties? I tried going into that but all the items in the Columns tab are greyed out.
Michael Aivaliotis
VI Shots LLC
(3,221 Views)
Ok, I right-clicked on the control and replaced it with a new one from the TS palette and it seemed to have fixed the problem.
Michael Aivaliotis
VI Shots LLC
(3,219 Views)
