NI TestStand
step execution in teststand
hi ,
i excute a step in external instance of Labwindows CVI and i can't excute it in-process anyone help me please
thank you
(2,823 Views)
Hello ahmedkochbati92,
What do you mean by you cannot execute? Are you getting an error? If so, which error are you getting? A screenshot would be helpful!
Saki K.
(2,763 Views)
hello Saki K
my objectif is to create a sequence using a CVI code module for a CAN communication,the CVI code run properly.
i build a DLL from my CVI.c code, i have a problem in parameters value expression and the result failed .
i need to know if i must build a dll from my CVI code and call it in Module in step setting or i call the 'CallCVICodeModule.dll' like i found in the document .
thank you
(2,757 Views)
I am a bit confused by the screenshot you attached. It seems like in the Capture02.png, you left the <This expression cannot be empty> fields empty. Have you tried entering a value in there?
Saki K.
(2,742 Views)
