NI TestStand
step.result.string
I'm new to the C#/TS combination, and just trying simple things.
I'm trying to setup a string value test, with some simple interaction with my C# code.
I was able to pass a string value as a parameter to TS and store it in a local variable. That way i could test it agaist my limit.
However i do not comprehend how the Step.Result.String can be passed from C# to TS.
I found some examples and tried something.
In the attaced Ts.png - what am I missing in the yellow field ?
Can anyone provide a simple C# example combined with a picture of TS settings for a string value test.
Alternatively - where can i find it ?
thanks a lot
br
Nikolaj
(4,623 Views)
I believe i found a solution.
cs_s.png / ts_s.png
(4,580 Views)
