NI TestStand
steps template pane transfer
I create templates in my test, now I want all users for teststand on other pc's to be able to merge the same templates I have/make.
How can this be done.
Where Is this template ini a file located?
(4,690 Views)
C:\ProgramData\National Instruments\TestStand 2010 SP1\Cfg
It's a file called Templates.ini
It is binary so not sure how to merge them without going through the TestStand API.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,679 Views)
Indeed there is the file.
I was searching in de "C:\program files" but I had to search in the "c:\program files(X86)".
Thanx anyway!
(4,670 Views)
