This widget could not be displayed.
NI TestStand
storing a teststand sequence context
hi, i want to store a teststand sequence context in teststand variable using labview code , is it possible ? if yes then may i know how ? i tried using set Property value api in labview but i didn't get which type of data structure to use.
(3,035 Views)
Accepted by topic author giri2309
I don't understand why you are willing to store the sequence context in a variable since it already is...
Anyway you can use this method:
Rodéric L
Certified LabVIEW Architect
(3,032 Views)
