NI TestStand
string problem
Is it a known problem that Test Stand doesn't recognize a string correctly if there is "\T" in the string?
For example if you put "fd\Tfd" in a string variable and try to read it by using the Message Popup, you get fdfd.
I am using the Test Stand 3.1.
Any idea?Patch?
(3,055 Views)
That's standard character constants so '\t, will be a TAB character. If you want a blackslash you have to use '\\'.
Regards
Ray Farmer
Regards
Ray Farmer
(3,053 Views)
I see, it's a kind of "C" logic. As a VB user I find it a bit strange that the program is representing something that is inside of "", but I have to live with it :-).
Thank you very much for the quick response.
Igor
(3,047 Views)
