NI TestStand
subsequences pass fail
I have subsequences in my Main Sequence. In the current file.  Is there some attribute or something I can set so that this subsequnce doesn't report pass/fail when I call it in another subseq??  In other words I have a subseq called powerdown.seq.  In another sub seq I do some testing then in the clean up I call powerdown seq.  This is done many times in diff subseq.  Each time powerdown.seq reports pass fail.  Do I have to go into each subseq and deselect the "Record Result" button in "Run Options"?? Is there any where I can do it 1x?
(2,861 Views)
For your powerdown.seq using the ActiveX module you can set the property for that sequence to DisableResults
Sequence.DisableResults
(2,852 Views)
