NI TestStand
task in parallel in teststand
I want to test a card with Labview (8.6) and TestStand (4.1) .I control Instruments (RF generator...oscilloscope...) and Power Supply of this card.
Is it possible in TestStand to monitor , in loop , the current consume by this card and in the same time ,execute all tests.
Because I want to stop execution of the test if current is upper than the limit i have decided.
How can I organize those tests ?
Think
Rock_31
(3,019 Views)
you can use Run VI Asynchronously to perform the monitoring function you are after.
Check out the following link.
http://forums.ni.com/ni/board/message?board.id=330&message.id=20622&query.id=533759#M20622
Regards
Ray Farmer
Regards
Ray Farmer
(3,014 Views)
