NI TestStand
test stand crashes: "test stand has detected that your script debugging"
Hi everyone. I am setting up a new installation of Test stand and writing my first sequence with an existing sequence of legacy code.
When I run the sequence and stop on the call to the DLL, and then step into the dll and I get this error:
test stand has detected that your script debugging settings might cause visual studio to hang when attaching to the teststand process to perform this step into operation.
To fix this problem, open internet explorer, select tools>>Internet options>> Advanced, check Browsing>>Disabl script debugging, click okay, and restart your sequence execution.
The message is vague and it is indermanent as to whether I should "enable" or "disable" Script debugging so I tried both. Test stand then crashes again and I get the same error.
Do I need to reboot after each crash? I'll try that next. Any ideas on how to make this error go away?
Thank you for your help.
Richard
(2,827 Views)
(2,817 Views)
