NI TestStand
testStand shared variable
hello,
i m using the Building a TestStand UI with Native Controls - CVI example to open and run sequence file and i want to share variable from teststand sequence file to the executable that lunch it.
(1,616 Views)
Hello KarimS,
You need to share a variable to an application exe which is been launched as a part of Sequence step.
Is your application build using LabVIEW?
Do you need to pass the variable during launch/start of application or continuous sharing?
if your application is build via LabVIEW and you need to share only during start of the application you can pass via argument handling.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,570 Views)
hello,
no my application build using labWindows CVI,
the application exe launched from my desktop and after that the application launch the Sequence File,
i need a continuous sharing of variable or data between the application and the sequence file
(1,544 Views)
