NI TestStand
teststand中利用ACTIVEX/COM 创建变量
在teststandII中lesson1 中: 如何利用activeX/COM 动态地插入一个局部变量?
Develop a small sequence that programmatically insert a local variable using the  Active X/COM adapter.
(2,389 Views)
The steps needed to dynamically add a variable are covered by this KnowledgeBase article:
How Can I Programmatically Create Variables in TestStand?
Just change the lookupString to the local name you require, eg. "Locals.NewVariable"
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(2,363 Views)
