NI TestStand
teststand中调用labview并行程序遇到的问题
hi
   各位,我现在用labview控制3个编程器对PCB flash,3个独立的控制编程器的vi放在另一个vi里(3个vi并行放置),运行这个vi时,3个编程器一起开始编程,即并行运行,现在把这个vi通过一个action在teststand中调用时,3个编程器不能并行运行了,现象是先一个编完,再另一个开始编,编完后再下一个,成了顺序结构,请问各位大侠,这是什么问题,怎么解决!!
(3,387 Views)
[Translated message:
Ladies and gentlemen, I am using labview control of three programmers on the PCB flash, 3 independent control of the programmer in another vi where vi (vi 3 placed in parallel), run the vi, the three programming Start with the programming device, which run in parallel, and now this action in the teststand vi through a call, the three programming Can not run in parallel, the phenomenon is the first of a series finished, and then another began to be compiled, and then complete the next series, became the order of the structure, may I ask you heroes, which is What is the problem, how to solve!]
Just one point, if you are going to post here, try to post in English or use one of the dedicated language boards.
Any way, I have added a Google translation of your post to this reply.
Are you running you VI from a SequenceCall that has been set to run in a New Execution?
Maybe you can post a screen shot of your Step and Sequence setup.
Regards
Ray Farmer
(3,384 Views)
