NI TestStand
teststand 2016 program throws out of memory error after running 2 days
I had developed test sequence in teststand 2016 SP1 which should run continuously for 60 days.. After running for 2 days, program crashes and throws out of memory exception error. I did check On-the Fly report, Only display latest result and in result processing and in Model option, select discard results.. option still out memory issue happens.. What could be the solution?,
I am using windows 10 - 64 bits having 4GB RAM
Appreciated and thanks in advance
(3,141 Views)
error message :
Report
Error, An exception occurred inside the call to .NET member 'GenerateReport':
System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.\r
at System.Text.Encoding.GetBytes(String s)\r
at NationalInstruments.TestStand.Shared.TSDotNetLib.ReportFileStream.Replace(Int64 offset, Int64 size, String data)\r
at NIOTFReportGenerator.OTFRptGenerator.GenerateReport(SequenceContext sequenceContext, String inputReportHeader, String inputReportFooter, ReportSection& mainSequenceReportSection, String& errorMessage, Double& errorCode, Boolean& errorOccurred)[Error Code: -2147024882, User-defined error code. ]
(3,139 Views)
Troubleshooting Memory Growth Issues in TestStand Systems
This document and its sub-docs have loads of good info on this topic.
-Trent
https://www.linkedin.com/in/trentweaver
(3,130 Views)
thanks WireWaver for reply . How to check memory in CPU -task manager -performance?
how to check individual memory usage in .net or other field memory usage? Initially when program started I looked on performance screen for 1 hour , CPU memory wasn't increasing in first hour. My program has mainly two main - for loops inner is runs for 270 iteration/day (each iteration is of 5 minutes) and outer is running for 60 days. So I can i assume if memory won't increase in first one hour than it shouldn't increase in subsequent time?
thanks,
(3,124 Views)
