NI TestStand
teststand array with visual basic
Hi
I have a function under VB 6.0 which need an array of string
Ex :
Public sub example(ByRef test() As String)
End Sub
But on TestStand when i call this function, using a array defined on TestStand as a Array Of String for the function parameter, it doesn't work.
The error message is : "Incorrect Parameter"
So Is it possible to use array between TestTand and Visual Basic, and if yes How ?
Thanks You
S.Guillon
(2,963 Views)
There is an example in the Examples 'C:\TestStand\Examples\AccessingArrays\' which will help.
It access the array by passing the sequence context as such
Public Sub SetStringArray(SeqContext As SequenceContext)
Hope this helps
Ray Farmer
Regards
Ray Farmer
(2,963 Views)
