NI TestStand
teststand edit/replace multiple subsequence calls
Hi all,
is there a way to change the following properties of a subsequence call - like the replace/find tool?
1. find all subsequence calls
2. change all their setting "User Current File" from "checked" to "unchecked"
3. then, edit the "file Pathname" to be a, new, different sequence
thank you
Message 1 of 1
(388 Views)
