NI TestStand
teststand execution time setup
Hi.
I'm using teststand to command an array of tests on an embedded system. Teststand communicate with my system through uart.
How to setup the execution speed between each step ?
There is an option in configure->Station options for the tracing. but "slow" and "fast" aren't really precise. Is there a way to set that each step are precisely called every 100 ms for example ?
Thanks.
(5,310 Views)
You can use a Wait step to set a time between each step. This way you can be sure there will be 100ms between the end of step 1 and the start of step 2.
There is no way to set the time between the start of each step (for instance starting step 2 100ms after the start of step 1). TestStand is not a real-time software, there is no data about how much time it could take to start a step done by LabVIEW for instance.
Mathieu P. | Certified LabVIEW Associate Developer
National Instruments France
Journées techniques : des fondamentaux aux dernières technologies pour la mesure et le contrôle/comm...
(5,281 Views)
Ok. Thank you for this information.
(5,279 Views)
When u send a command to the embedded system - you could wait for a return acknowledgement from it before starting the next test.
This requires embedded software to have this handshake protocol in it.
(5,267 Views)
I am already sending aknowledgements between messages. It happens sometimes that mcu is sending its aknowledgement too fast after receiving a command from teststand, and teststand miss this message and remain blocked, waiting for an aknowledgement that has already been sent.
Therefor i wanted to know if there was a mean to fix or to know the time needed for teststand to pass from one step to another.
But i found a workaround on my test application.
Thanks thro
(5,262 Views)
If you have used buffers in UART code you should not have missed the acknowledgements.
UART works at a very slow pace compared to PC speed.Please look into it.
Adding delays in the TestStand level is ok but not the best solution in this case.
As rightly pointed out by others PC does not use a real time OS.If delay works fine on some system it may not on others unless you give a huge delay which may be not effecient.
(5,259 Views)
Well, i increased the buffer size but it didn't work.
As said, I found a work around.
(5,223 Views)
