NI TestStand
teststand labwindows
Hello To All,
I am new to Teststand and have created a project under LabWindows/CVI. I want to use Teststand as the executive. Is there a sample that shows you how to use teststand and CVI?
ThanksNAdvance!
(3,393 Views)
You can full the advive giving by Antonio
http://forums.ni.com/ni/board/message?board.id=330&message.id=7687&query.id=60557#M7687
I am sure the is a KnowledgeBase on this on the NI website.
Regards
Ray Farmer
Regards
Ray Farmer
(3,383 Views)
FredTest,
Have you read the Using LabWindows/CVI with TestStand manual?
I would recommend you to check it out.
You can find it under the TestStand Bookshelf (Help->Search the TestStand Bookshelf).
Hope it helps.
Antonio Lie.
(3,383 Views)
Here is the link to the Knowledgebase I mentioned earlier.
http://digital.ni.com/public.nsf/allkb/52f5bb7ae7f5a409862569ee0073ac53
Regards
Ray Farmer
Regards
Ray Farmer
(3,366 Views)
