NI TestStand
teststand migration from 2019 to 2022
Hi all,
I'm migrating my .NET development arround TestStand plateform.
For that, I changed all TestStand API reference from 2019 to 2022.
I developed an assembly (DLL) which implement edit panel for StepType.
If I use TesStand 2019 with the new build (with 2022) I get an error :
I would like to have only version of my DLL usable from TestStand 2019 and 2022.
Is it possible to do that?
Thanks in advance for your help
(856 Views)
From this link https://download.ni.com/evaluation/teststand/Creating_Custom_Step_Type_Edit_Tabs_in_the_Sequence_Edi...
" Each major version of TestStand will require its own build of the edit tab panel targeting the correct TestStand assembly and .NET Framework versions. "
It looks like you need to rebuild for different versions as there are dependencies on Version specific DLL while you build your DLL.
Ravi
(800 Views)
