NI TestStand
teststand to record the test time
Hi Sir,
My teststand will generate the xml test report, can see the total test time.
But i want to breakdown the test time, and see it for each step.
How to config it, then the test report will record the test time for each step ?
Keep moving
(1,841 Views)
You can add the time value to the report by using the following:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8tKSAS&l=hu-HU
You can also add to be visible in the SequenceEditor:
https://forums.ni.com/t5/NI-TestStand/Displaying-the-module-time-for-each-step/td-p/3759197
CsBihacker
(1,801 Views)
hello,
I go through that, but still have not seen how to make it happen.
Thanks.
Keep moving
(1,797 Views)
The answer is in this forum link:
https://forums.ni.com/t5/NI-TestStand/Add-step-module-time-in-report-document/td-p/2954759?profile.l...
Basically, the XML default stylesheet (horizontal.xsl) doesn't display it so, you will need to update it to any of the other two options.
(1,793 Views)
