NI TestStand
teststand turn off enter uut number
HI I am new to teststand and just wanted to know how do I turn off the dialog box that popus up for every run saying enter uut serial number when I select test uuts? How do I tunr off the test sequence passed dialog at the end?
(4,686 Views)
i have not mess with that dialogs... but you should look into the Callbacks.. thats where you are going to be able to disable them and pass a constant to them
Right click on the MainSequence under the sequences tab. select sequence file callbacks, it might be under PreUUT..
under that sequence it will be a  CallDoPreUUT step.. that step is the one that handles the dialog. be carfull because you will need to pass some paramters to other variables to make it work how you want it. at the end of the test it will loop if you dont click finish.
CLAD, CTD
(4,669 Views)
Hey id,
I found another forum post that addresses this issue, you may find it helpful:
http://forums.ni.com/t5/NI-TestStand/How-Do-I-Disable-UUT-Serial-Number-Dialogue-Box/td-p/2896888
Libby B.
Applications Engineering Specialist - RF Wireless
(4,625 Views)
