NI TestStand
the duration of the "Аction" and save the data in Excel
I have some questions.
1) I need to set and regulate duration of the "action." for example, to "step 1" was performed for 5 seconds, then "step 2" was performed for 3 seconds, etc.
2) and I need to save the data. 100 readings per second. is it possible?
(4,180 Views)
Are you using this example?
https://www.ni.com/docs/en-US/bundle/teststand/page/model-plug-in-basic-step-time-report.html
It may be useful for you.
Cheers,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,168 Views)
thank you. but it is very diffiicult for me...I'm a new user. I need to record data 10 values per second may be. It's enough. For example, I set the current value  1A, then measure the voltage for 1 second. And I have to record 10 points in the second. is it possible?
first I would just record data to the txt file.
(4,159 Views)
One option is to have the VI loop and control the loop with timing.  Then return each of the measurements to a Multi-numeric limit step.
Just a thought,
jigg
CTA, CLA
testeract.com
(4,136 Views)
