NI TestStand
timed while loop
I have to time a while loop in order to go to my clean up if the step into the loop won't excute at the specefic time that i want.I find how to time a loop in this forum so i code my program as shown in the snapshot.Is my idea correct?
(3,605 Views)
Good morning:
A couple questions:
1.) What is the While statement? It is being cutoff on the JPG.
2.) The IF statement 'PASS Wait for TimedLoop', will not work.   The NI_Wait step type does NOT return a PASS/FAIL result, plus you are NOT recording the result of that step.  You would have to pass this on some other criteria.
3.) Where does Locals.b get initialized?
PH
(3,586 Views)
Hi Teds,
Thanks for your reply.I'm sorry for responding you lately:)))
1-I need a pass/fail condition in the while statement "which is not available in test stand" so i copied the condition from an if statement and i put it into my while statement and it works.
2-You're right,i modified it as shown in the snapshot.
(3,545 Views)
