NI TestStand
trouble viewing xml reports
When I run my sequence under single pass, the xml report generated cannot be viewed because of this errror:
The XML page cannot be displayed
Cannot view XML input using style sheet. Please correct the error and then click the Refresh button, or try again later.
XML document must have a top level element. Error processing resource 'file:///D:/TEST_directory_mockup/Test_HW_Manipulatio...
I am posting the stylesheet I am trying to use. I believe the report options are configured correctly in TestStand, I can give you details about them if needed. Also, I made sure that the stylesheet exists in the correct place in the NI folder. To keep things further safe, I even pasted a copy of these stylesheets in the folder that contained the xml report.
Any comments/suggestions will be greatly appreciated.
Anuj
(3,394 Views)
Hi
Can you please post the report which displays this error and what modifications (if any) you have made to the reporting process.
Thank you
Anand Jain
(3,385 Views)
I am attaching an xml report file that was giving me the error, the expand.xsl stylesheet, and a snapshot of what the report options in TestStand look like. I did not make any changes in the sequence files that deal with reporting.
Anuj
(3,381 Views)
Hi
It looks like your report is empty. Is this the correct report?
Anand Jain
(3,376 Views)
