NI TestStand
.tsd not opening
I have inherited a project from an old collegue.
Now I want to take a look into his .tsd file but when I want to open it it briefly shows te settings but after 1second it closes and opens a new Deployment.
Is there somewhere a log file to know what is wrong?
Maybe the location where I put all files is wrong, how can I check what is the correct location?
(1,667 Views)
Can you post the tsd file that is causing this issue?
Anand Jain
NI
(1,636 Views)
yes  i can
(1,613 Views)
The tsd file is looking for a folder called c:\gets. Since it is not able to find it on my machine, it prompts for a folder to replace c:\gets.
you can hit cancel and you should be able to look at the files referenced by the tsd file.
If you do not see the same behavior, can you post some screenshots of TSDU when you open the attached tsd file.
Also, what version of TS are you using? I tested using TS 2021 64-bit.
Anand Jain
NI
(1,597 Views)
I`m using Teststand 20.0.0.49180 (32-bit)
I get no warnings. I can can see it`s opening. ( deployment version shortly blinks 1.0.30) but after a fraction of a second it opens a new Deployment...
(1,590 Views)
up...
(1,551 Views)
