NI TestStand
type conflict in OI
I have several sequence files that make use of sequences in one common sequence file. There are two container types defined in that common sequence file (not, unfortunately, in a type INI file, I inherited it that way).
When I try to start the master sequence, that starts all others, from an Operator Interface (this is the full-featured MFC example coming with TestStand 4.1), then I get a type conflict for both these types and the recommendation to open the conflicting files in the sequence editor and resave them.
The sequence editor does not show any type conflicts. Resaving the files does not remove the error in the Operator Interface.
Any suggestions? (this is all TestStand 4.1).
Best regards
Peter
(3,076 Views)
Peter,
i take it that both types are defined in the same (*.seq) file. The dialog tells that there are more than one file involved in the conflict. Is that correct?
Is it possible, that the UI loads an older version of the sequence file by default as well?
What is the general setup in the UI when the conflict occurs?
Maybe you can attach some screenshots of the dialog in order to clear things a bit up.
thanks,
Norbert
Norbert
Expert: Geometry
(3,055 Views)
