NI TestStand
unload java class
Hi everyone,
I have problem with unloading java classes. When I update java class file, it does not take effect unless I close TestStand software.
Closing Sequence .seq file does not take effect. It should, right? (according to the Known Issues published by NI).
If only I close TestStand, the updated classes take effect.
It is quite annoying that I have to close TestStand everytime I change the Java class file.
Is there any better solution than closing TestSand?
Thanks for helping.
(3,769 Views)
Have you tried doing "Unload All Modules" in the File menu? Not sure if it will work, but it's worth a try.
-Doug
(3,752 Views)
