NI TestStand
unload the code modules
Hello All,
I am using LabVIEW 2012 and NI Teststand 2012. I have experenced many a times that when I want to unload the code modules . some times/ many a time test stand does not relase LabVIEW code modues .Teststand will be still holding the LabVIEW code modules.After performing many time of unliding the modules in teststand also code module does not get released .
please suggest me if there is any other way or method to release the code modules .
Prithviraj
(4,186 Views)
@Padugur wrote:
Hello All,
Prithviraj
Did you tried unload options in step settings properties? as attached
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,172 Views)
Hi ,
Thanks for replying , my sequence steps are set as per your suggestion .
my requrement is teststand doesnt not allow VI , to release . after unloding the modules in teststand.
Prithviraj
(4,163 Views)
@Padugur wrote:
Hi ,
Prithviraj
Not Releasing means, After completing the whole sequence or after executing that particular step?
whether your code module is one time run vi or looping ?
(4,159 Views)
