NI TestStand
unresolvable prototype mismatch with CVI adapter
After changing prototypes  I'am getting  an error indicaor in the Step settings windows which says :
" the parameters specified by the step do not match the function prototype" :
(3,764 Views)
Sorry,a liitle bit fighting with the editor
But after pressing the "verify prototype" button there is no error:
Trying to fix the problem by pressing the button with the exclamation mark gives :
But now "verify prototype" is unhappy:
And fixing that I'am again at the start point.  How/where to fix that problem
(3,758 Views)
1) What version of TestStand?
2) What is the exact actual prototype in your code?
3) Are you using a type library to include the type information in your dll?
-Doug
(3,751 Views)
4.2.1.83
void __declspec(dllexport) Sensor_RF_Pulsetop(CAObjHandle seqContextCVI, double *measurement,
 char reportText[1024], short *errorOccurred, long *errorCode, char errorMsg[1024],
 long Channel, long Pulsemode, long Power, long Powermeterhandle, long Counterhandle)
No.
-Doug
(3,738 Views)
Accepted by topic author markus kossmann
Based on the information you provided, my best guess would be that the DLL specified for the step is not the one created from the source code. It appears that the function that TestStand finds in the DLL does not contain the last 4 parameters.
Did you recompile the CVI project? Did the path to the DLL change?
(3,706 Views)
Yes you are right. I changed the CVI  but I didn't rebuild the DLL
(3,686 Views)
