NI TestStand
updating Station Globals in specify module
I tried to specify a vi in a sequence and choose a staion global to receive the data from the vi.
But the staion global is not getting updated as expected. But I received the variable in a local and then in post expression i assigned it to the station global. This updated the station global.
Can you please explain me what is the problem associated with the behaviour?
Regards
Gopal
(3,277 Views)
Gopal,
What version of TestStand and LabVIEW are you using?
Can you post an example?
Using a station global variable as the value of an output parameter should update the variable.
Regards.
Antonio Lie.
(3,271 Views)
Iam using labview8.2 and teststand3.5. Iam unable to reporduce the problem today. I will post the vi once iam able to reproduce it.
Thanking You
Gopal
(3,258 Views)
