NI TestStand
using post expression to copy more than one local variables
In TS 3.5, and in post-expression, how do I write an expression to assign new values to local variables.
ex: I have a multiple numeric limit test, using LabVIEW VI, at the end of the test, the LabVIEW VI has 3 values in the
Numeric Measurement array.
using post-expression, how do I replace three TS local variables with the three new values returned by
LabVIEW VI.
locals.a=step.NumericArray[0],
locals.b=step.NumericArray[1],
locals.c=step.NumericArray[2]
Is this the correct syntax?  is the comma the correct separator?
If I would like to copy the whole array, can I write
locals.myArray=step.NumericArray ?
(3,261 Views)
the coma is the correct seperator but the syntax would be Locals.a=Step.NumericArray[0], but the highlighter would guide you through the correct syntax.
If you could just assign an array to receive the return data as you have detailed.
There maybe some array examples, but they maybe early examples (TS2.x) in the TestStand examples folder.
Regards
Ray Farmer
Regards
Ray Farmer
(3,253 Views)
