NI TestStand
using the previous step's output as next step's input in teststand
dear sir/madam;
I developed an application in labwindows CVI which executes in CVI currectly.Then I executed it  in Test stand.
I created an Action  step for
int Pbit(unsigned char bit_data[50000])
"bit_data" is the output of this  function.The next Test Stand step is a "Pass/Fail" step for
int Vme_test(unsigned char *bit_fail_data,int *vme_stat)
"bit_data" is the input for this function and vme_stat is the out put which is generated by using "bit_data".
My question is how to identify  "description" and "value expression" of "bit_data" as given in attached files.I tried fileglobals but I think I didnot identify it correctly and I received "No size info" error.
Waiting for your immediate reply.
Best Regards
Message 1 of 8
(5,524 Views)
You could store your return value in say a local variable eg "Locals.MyPbitResult". Therefore in the Value Expression inset "Locals.MyPbitResult" (or some other such suitable named variable)
Then in your call to vmetest your input you would use "Locals.MyPbitResult" in the Value Expresion and your output use "Step.Result.PassFail", I am assuming you have used a Pass Fail Step Type for the vmetest step.
Have a look at the example TestStand\Examples\AccessingArrays how information is passed from one step to another.
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 8
(5,513 Views)
thank you form your immediate reply.But I've tried the way you described.It did not workals.But I think I have problem about the type of the local.As you know my variable is unsigned char(or string array in other words).Which type of local I must identify?a string? a number?a container?
thanks
Message 3 of 8
(5,510 Views)
You probably need to use a string in TestStand.
Regards
Ray Farmer
Regards
Ray Farmer
Message 4 of 8
(5,506 Views)
Dear Ray;
I've tried as you adviced to identify a local but although I idnetify my array size as bit_data[50000] it always stops at "2576" when copying my string to bit_data[50000].Then teststand gives 17702 error and stops.Although until 2576 the for loop below;
for (q = 0; q< 5000; q++)
   {   bit_data[q] = bit_data_1[q];
works, at magic number 2576 it stops and "no size info" error appear in the watch window for bit_data content.
My code is attached below.I'm still not sure how to identify my test stand step variable description and value expression for this function.
Waiting for your help 😞
Best regards
Message 5 of 8
(5,474 Views)
I tried your code,
In the TestStand I configure to pass an array of numbers, instead of a string, seems to work ok.
see attached jpg.
Regards
Ray Farmer
Regards
Ray Farmer
Message 6 of 8
(5,447 Views)
Hi Ray;
I did what you said.But I can get only the 0..499 array elements.When it's time for getting  the 500. element to the local varialble "no size info" returns.Is there any limit for number array elemnets.Although we set the Dim size 50000 it stops at 500.Is there any other setting to set higher?
Best Regards..
Message 7 of 8
(5,431 Views)
I dont think so, are you using TS3.x?
When you say it stops at 500, where about does it stop.
Do you have an example of your sequence file that shows this problem.
Regards
Ray Farmer
Regards
Ray Farmer
Message 8 of 8
(5,424 Views)
