NI TestStand
vi stops in operator interface
i have the following problem:
i made a custom steptype (TS3.0) that has been running fine for a while. Since a few month the vi (LV7.1.1) stops in the operator interface (only there, in the sequence editor it is ok). The frontpanel pops up (this is not ok) and the vi waits before i hit the button "back to executer". Then in the operator interface i must hit "continue execution" and the sequence runs normally. This problem occures only at the frist start of the sequence.
any ideas?
greetings
schwede
(3,104 Views)
Hi schwede,
first, let me make sure I understand what the problem is:
You created a custom step type that runs a LV7.1.1 VI and use that in your sequence. It all worked fine until a while ago.
Now at every first call of the custom step, the front panel of the VI pops up and executes, then waits for you to manually close it. Once it is closed, you have to manually start the sequence again. The sequence can then keep on running correctly.
Please let me know if I understand that correctly.
One question that would come to mind is, did anything on the machine change between the time where it worked and the time where it didn't? Can you think of any software upgrades that might have been installed?
(3,068 Views)
i have found what was wrong. It is the basic setting of TS. Ohoh.
Thankyou for your reply.
Schwede
(3,041 Views)
