NI TestStand
viewing operator interface from remote pc
sw: win2000, labview 7, teststand 3
hw: scxi 1000, scxi 1102
Q1: How do I set up the LV Operator Interface, so that I can view the test on a different pc with LabView only?
Q2: if Q1 is possible, if I have two executions (ex1 and ex2), how do I specify the execution ex1 or ex2 for viewing from the remote pc?
(2,979 Views)
Hello Trout-
The simplest way would be to explore the possibility of customizing the LabVIEW VIs to be remote panels on your new machine. You may want to consult your LabVIEW user manual about how to customize a top Level VI to be a remote panel as it will have more information about the strengths and weaknesses of the environment as far as how to make items active and if you can toggled between views. It may require that you customize your Operator Interface to better suit your needs.
-Regards
Elaine R.
http://www.ni.com/support
(2,979 Views)
