NI TestStand
weird step type menu behaviour
I am having problems getting a menu item to show up in the step type menu using the menu configuration tool, even though it is shown as unhidden.  I attached an image.  What could be wrong here?  I restarted teststand also.
(3,370 Views)
It looks like that group is empty.  TestStand will not display empty groups.
Allen P.
NI
(3,365 Views)
David,
Are SetLightIntesity and VISA_WriteOrQueryWithSRQ surposed to be under Instrumentation rather than StationHardware?
Regards
Ray
Regards
Ray Farmer
(3,352 Views)
Well, I swear the step was inside the folder just prior to taking that screenshot, because I couldn't get at the step type I deposited in the folder because it was hidden (my first indication of a problem).  I then moved it back out so I could see it and use it, then I took the shot.  I should have taken the screen shot prior, because now I cannot reproduce the issue.  I moved the step back into the folder and it showed up.  So chalk it up to quirky behavior.
Message Edited by david_jenkinson on 09-12-2007 11:07 AM
(3,332 Views)
