NI TestStand
what function do I use to programmatically create End steps with onNewStep
I want to create a custom step type that is a Label with an End step for labeling blocks of code.
I tried Custom substep with OnNewStep, and I put in the function OnNewStepWithEndStep  from NIFlowControl.dll, but it's not working. By that I mean when I drop the Label step the end does not get dropped too.
I found this link, but it's lacking the detail I need. Thanks.
http://forums.ni.com/t5/NI-TestStand/Custom-step-to-Open-edit-expression-when-placed-in-sequence/m-p...
cc
(4,554 Views)
There are 2 subproperties you need to change:
BlockEndTypes needs to be NI_Flow_End
AppliesToBlockStructure needs to be True
So if you expand your step in your type palette you should see those subproperties.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,536 Views)
