NI TestStand
where icons are stored
I have a basis folder for all of my TestStand projects, which contains all the project relevant things. In the station options -> Preferences -> Configuration directory I have set my config folder, everything looks fine.
But, my customized icons are loaded only from the TS default location:
C:\Program Files\National Instruments\TestStand 2010\Components\Icons
Is it possible to change this path to my project folder?
(4,620 Views)
I had the same task. I also found out that icons in the search dirctory does not care.
I think thats clear, because TS loads all icons before initializing project stuff.
Just a note:
You should not use C:\Program Files\National Instruments\TestStand 2010\Components\Icons because it should be private by TS.
You should use PublicComponents folder instead.
Normally this is: C:\Users\Public\Documents\National Instruments\TestStand 2010\Components\Icons
or find it via statement: RunState.Engine.GetTestStandPath(TestStandPath_PublicComponents)+\\Icons
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,602 Views)
