NI TestStand
why is adapter support file keep running?
Please look into attachment
(3,258 Views)
Hello Sonet -
I made a DLL from your C code, and then adjusted the paths and ran your sequence. I have my adapter set to 'run in process' which means that I am not using my tscvirun.prj or any of it's associated files. After doing these three things I execute your code and have no extra windows opening or closing. TestStand calls the DLL and runs both steps silently before cleanly exiting.
Is there something else I can try here to try and duplicate the StringTest only misbehavior that you are seeing?
--Regards
Elaine R
http://www.ni.com/support
(3,258 Views)
Hi Elaine
Reagrds
Sonet
(3,258 Views)
Hello Sonet -
The tscvirun.prj should only 'popup' on a step of there is a breakpoint somewhere in the C code, or if you have instructed TestStand to 'step into' the step. Check through the tscvirun.prj for any breakpoints. If you don't see them, you may want to rebuild the tscvirun.prj with a fresh copy by investigating Configure>>Adapter>> CVI Standard Prototype Adapter settings. You should see a button that will let you reset the tscvirun.prj here.
-Regards
Elaine R.
(3,258 Views)
