NI TestStand
why my Programmatically start sequence executions doesn't work?
hi, I find problem to start an "Test UUTs" execution programmatically.
Actually in my LabVIEW OI, I use the invoke node of the sequencefile view manager to get object of "command" with the option "0" ,( i see it it in example OI that the "commandkinds_entrypoint_set" is used to set the teststand oi control button named "Test UUTs"), and then use the method of "execute" to try to run the sequence.
But it seems it doen't run the sequence.
What's wrong with my way or how to programmatically run a sequence with entry point?
(3,322 Views)
further issue about "get command",
it has only one parameter of default value 0, and when get the object "command", it has method "execute" with no parameter
how does it set command_kinds which has parameter?
i.e. the execute entry point could be "entry point 1" or "entry point 2", which need different parameters.
and maybe other command_kinds need other parameters.
(3,313 Views)
