NI TestStand
why the test report's failure chain only display the first failure?
Hi All,
    why the test report's failure chain only display the first failure step?how to get all the failure steps in the failure chain?
    Thanks a lot.
BR
Johnny
(4,190 Views)
Try TEDS example here
Regards
Ray Farmer
(4,186 Views)
Hello Ray,
    Thanks for your reply.
    It seems so complex.is it teststand's bug?
BR
Johnny
(4,184 Views)
i tried it,it does not work.
(4,181 Views)
Did a quick search and came across the following links
http://zone.ni.com/devzone/cda/tut/p/id/4563
http://zone.ni.com/devzone/cda/epd/p/id/3326
Regards
Ray Farmer
(4,175 Views)
    thank you.
    i am using XML format.So i copied the reportgen_xml.seq to C:\Program Files\National Instruments\TestStand 4.2.1\Components\Models\TestStandModels.And when i runned the example "XMLReportTest.seq".the report is ok.
    But when run my own sequence,it does not work.and it is so strange that when only one step failure,it is ok.when occupied
 two or more failure steps. it is error.
(4,157 Views)
the error message in below for your information:
details:
Error executing 'For' step.
Error in For loop condition expression.
Error in argument 1, 'Parameters.Result.TS.SequenceCall.ResultList', in call to the expression function 'GetNumElements'.
Unknown variable or property name 'Parameters.Result.TS.SequenceCall'.
error code
-17306; Unknown variable or property name.
Step 'For' of sequence 'UpdateFailureStack' in 'reportgen_xml.seq'
(4,156 Views)
