NI TestStand
write in variable runtime with C# UI and TestStand
    I am modfying the C# UI interface for testStand. I have a variable in TestStand -> Locals, and I want write in this variable fromr the C# UI.
    How can I write or read TestStand variable ?
Thank's
Grégory
Message 1 of 8
(4,737 Views)
Hi Gregory,
I assume you what to write/read when your Uut or an execution is running.
If I am right i would fire a PostUIMessage from the execution to C# Ui.
On reveiving this message in your UI will be able to get a handle to SequenceContext
now your world is open.
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 2 of 8
(4,724 Views)
Thank's for your response,
    In fact I have a checkBox in C# UI, and I want write state of checkbox in parameter(variable) in Testand.
    I will test your solution and give you a feedback.
Grégory
Message 3 of 8
(4,714 Views)
I have found some code on the forum, I muss use propertyObject for read or write a parameter.
this code is :
Private void Example (Step stepObj)
PropertyObject propertyObj;
String errorString;
propertyObj = stepObj.AsPropertyObject();
errorString = propertyObj.GetValString("Result.Error.Msg",0);
What is stepObj? where can I find them?
thank's.
Message 4 of 8
(4,711 Views)
If I understand you correctly, you want to pass the state of a checkbox to a parameter in a Sequence.
What you dont specific is whether this is during the execution of the Sequence or not.
I think your best bet would be to write the state of your Checkbox to the StationGlobals. Then let your Sequence pickup the value from the StationGlobals.
Regards
Ray
Regards
Ray Farmer
Message 5 of 8
(4,702 Views)
Hi Ray,
I agree your suggestion.
Hi  Costello,
for more information on C# and TS take a look at the example <ProgramFolder>\National Instruments\TestStand 4.0\Examples\Demo\DotNet
Greetings
Juergen
Message Edited by j_dodek on 06-12-2008 01:01 AM
--Signature--
Message 6 of 8
(4,699 Views)
Hello Ray, you have understand my problem. I have try to write in StationGlobal, but It don't functions, I have Testand 4.1.
I have try some exemple for write in StationGlobal, but any function.
Have you an exemple?
Hi Juergen, I have see the computer exemple, but that is not a GUI exemple, that is a dll.
Message 7 of 8
(4,690 Views)
I have uses StationGlobals :
axApplicationMgr.GetEngine().Globals.SetValBoolean("modeManuel",0,false);
Message 8 of 8
(4,647 Views)
