NI TestStand
write results to report file once per minute
Hello All,
If I understand correctly, the standard setup for report creation is to save all results to the report at the end of the test. I am running a Teststand script over several days, there is a chance power could be lost or the machine could fail. For this reason it makes sense to save results (typically the last minutes results) to the report file regularly. Is there any way to do this?
Regards
Chris
(3,099 Views)
You would be best to use 'On the Fly'. There is an example in test TestStand examples folder using On the Fly reporting.
Regards
Ray Farmer
(3,097 Views)
Hey Guys! On the fly reporting is definately the way forward. Here is a great KB which explains it in more detail...
On-The-Fly Reporting and Logging in TestStand
http://digital.ni.com/public.nsf/allkb/C9113BE0E55F22EE86256D82005E7DDB?OpenDocument
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(3,065 Views)
