NI TestStand
writed a dll for save string in teststand,get a error from teststand
I'm writed a dll for save string in teststand, the dll can execute by itself well,but when loading by teststand, it always error heppen,I attached all resource here ,please kindly help me on this,thank you in advance.
帖子被alexzheng在06-15-2006 03:19 AM时编辑过了
(3,161 Views)
What error are you receiving?
Regards
Ray Farmer
Regards
Ray Farmer
(3,151 Views)
HI,
I have resolved the problem, I have wrong define in the write function use : writetextfile(CString filename,CString text,int length)
but the error happen when I transfer those string from teststand to dll,it generation a system level error and automatic close teststand software occur,
after I change the define for :writetextfile(char *filename,char *text,int length) ,it is Ok now.
帖子被alexzheng在06-15-2006 06:44 PM时编辑过了
(3,143 Views)
