NI VeriStand Add-Ons Discussions
AIT ARINC 429 Add-On Feedback
Can you try this test build? Check the loop status channels and RX data
ftp://ftp.ni.com/outgoing/test 2.0.1 ait429.zip
Stephen B
Message 151 of 193
(1,372 Views)
I don't have right now the other card I have to wait an hour or so for data test.
But input loop duration is now updating with the new build.
If data test is also ok could you say me which VI I should modify to have everything working so that I don't have to do my specific modification again.
Thank you very much for your answers
Benjamin
Message 152 of 193
(1,372 Views)
Just did data test and we get nothing in Veristand.
Message 153 of 193
(1,372 Views)
Benjamin
Glad that fixed input loop duration at least.
You can see which VI I changed in the commit log here:
https://github.com/NIVeriStandAdd-Ons/AIT-ARINC-429/commit/fac8b9da8f6cb033c5b93658abaf34d62c1ac5c9
Stephen B
Message 154 of 193
(1,372 Views)
OK I'll keep looking
Stephen B
Message 155 of 193
(1,372 Views)
What channel numbers are you using for RX? Any way you can share your database?
Stephen B
Message 156 of 193
(1,372 Views)
We tried with a modified loopback not the full configuration.
Test on label ID 34. Other labels where just here to see if it didn't load the CPU to much but it doesn't look like it.
<?xml version="1.0" encoding="UTF-8"?>
<board429 xmlns="http://www.aviftech.com/Schemas/Databus/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.aviftech.com/Schemas/Databus/ file:///C:/Program%20Files%20(x86)/AIT/Flight%20Simulyzer%20(VISA)/AIT_429.xsd" sdiModeEnabled="false">
    <boardIndex>1</boardIndex>
    <channel429 channelNumber="1" name="Wheel Input" channelSpeed="HIGH_SPEED_CHANNEL">
        <Rx>
            <chronMonitor/>
            <labels>
                <label labelId="34">
                    <buffer name="1" depth="1" parityEnabled="true"/>
                </label>
                <label labelId="07">
                    <buffer name="Right Wheel SpeedIn" depth="1" parityEnabled="true"/>
                </label>
                <label labelId="08">
                    <buffer name="AltitudeIn" depth="1" parityEnabled="true"/>
                </label>
            </labels>
        </Rx>
    </channel429>
    <channel429 channelNumber="2" name="2" channelSpeed="HIGH_SPEED_CHANNEL">
        <Rx>
            <chronMonitor/>
            <labels>
                    <buffer name="2" depth="1" parityEnabled="true"/>
                </label>
                </label>
                </label>
            </labels>
        </Rx>
    </channel429>
    <channel429 channelNumber="3" name="3" channelSpeed="HIGH_SPEED_CHANNEL">
        <Rx>
            <chronMonitor/>
            <labels>
                    <buffer name="3" depth="1" parityEnabled="true"/>
                </label>
                </label>
                </label>
            </labels>
        </Rx>
    </channel429>
    <channel429 channelNumber="4" name="4" channelSpeed="HIGH_SPEED_CHANNEL">
        <Rx>
            <chronMonitor/>
            <labels>
                    <buffer name="4" depth="1" parityEnabled="true"/>
                </label>
                </label>
                </label>
            </labels>
        </Rx>
    </channel429>
    <channel429 channelNumber="5" name="5" channelSpeed="HIGH_SPEED_CHANNEL">
        <Rx>
            <chronMonitor/>
            <labels>
                    <buffer name="5" depth="1" parityEnabled="true"/>
                </label>
                </label>
                </label>
            </labels>
        </Rx>
    </channel429>
    <channel429 channelNumber="6" name="6" channelSpeed="HIGH_SPEED_CHANNEL">
        <Rx>
            <chronMonitor/>
            <labels>
                    <buffer name="6" depth="1" parityEnabled="true"/>
                </label>
                </label>
                </label>
            </labels>
        </Rx>
    </channel429>
</board429>
Message 157 of 193
(1,372 Views)
Hi Benjamin,
I cannot seem to find any issue here. I appear to be receiving RX data fine. Are you sure your external system is writing the labels that you're set up to receive?
Keep in mind that the XML shows the label #s in hex. So label 34 is really hex 34 or octal 64 or decimal 52. You can see the label #s in your sysdef page in any format you like.
Stephen B
Message 158 of 193
(1,372 Views)
Yes in fact it works fine if I define data parameters in XML file.
I was trying it adding a parameter directly from VeriStand and that is not working for me when I do that.
Since I will always have all data parameters specified in the XML configuration that will not be a problem.
Message 159 of 193
(1,372 Views)
Hi BenjaminM,
Can you post both sysdefs? The one that doesn't work and the one that does? This would help me debug. there shouldn't be anything different when creating through the GUI vs importing.
Thanks!
Stephen B
Message 160 of 193
(1,372 Views)
