NI VeriStand Add-Ons Discussions
AIT ARINC 429 Add-On Feedback
Some questions to help me narrow down the issue:
  1. What is the rate of NI VeriStand engine?
  2. If you use only 50 Hz TX labels, do you see the problem? Or is only when you use 200 Hz and 50 Hz?
  3. To clarify, you see one value for the TX parameter in NI VeriStand, but you see a different value on a bus monitor? Does this persist or will it eventually correct itself?
Stephen B
Message 81 of 193
(6,877 Views)
Nevermind I found the issue
Stephen B
Message 82 of 193
(6,877 Views)
What version are you using? I have a test build i'd like you to try before I post public
Stephen B
Message 83 of 193
(6,877 Views)
VeriStand version that is
Stephen B
Message 84 of 193
(6,877 Views)
Wow, that was quick.  I'm using VeriStand 2012.
Message 85 of 193
(6,877 Views)
OK try this
Stephen B
Message 86 of 193
(6,877 Views)
Works great!  Thanks again for the quick response and fix Stephen.
Message 87 of 193
(6,877 Views)
Awesome! I'll post it up
Stephen B
Message 88 of 193
(6,877 Views)
OK I just posted the official versions online and updated everything. Its the same as what I gave you so no need to redownload if you dont want to.
For my curiosity: do you see a performance difference between 1.7.2 and 1.8.0/1.8.1?
Stephen B
Message 89 of 193
(6,877 Views)
Yes, I see a significant drop in CPU usage going from 1.7.2 to 1.8.1
Message 90 of 193
(6,877 Views)
