NI VeriStand Add-Ons Discussions
ASAM HIL API for NI VeriStand 2012 Feedback
Hi Balazs,thanks to you patient reply. It helps a lot.
Message 11 of 16
(2,215 Views)
hi Balazs,with the NI HIL API and your help,our project proceeds smoothly.
But some performance issues need be improved when there are more capture variables or capture time is
long(e.g. our project capture 200 variables,capture time is not long,about 2s).In order to generate
report, we need get capture data with the ExtractSignalValue method to extract each capture variable's
data. When data size is big(capture variable number is big or capture time is long), the
ExtractSignalValue method spend about 5s or even more time for each variable. With 200 variables,it takes
about half an hour to get all data. Compared with other steps,this step is too slow. So, is there some
clever method? or can you help implement the GetSignalGroupValue method,or can you supply a method to
access the inner TDMS file so that we can analysis file ourselves.
In addition,there seems to be some problem with MAPort.Write() when model path contain //, the method
fails but Read() method is OK.
That all,thanks!!
Message 12 of 16
(2,215 Views)
I just find that this add-on is provided as open-source software. How can i get the source code?
Message 13 of 16
(2,215 Views)
We have been noticing that while trying to use NI HIL API  it takes around 80-100 seconds per variable to extract data and it increases for more variables and the length of the capture. This is hindering us from using the Veristand HIL effectively as for some of our testing we need to capture more than 100 variables and then analyse them.
We use the NI HIL API inside dSPACE Automation Desk software. With the help of dSPACE we proved that it was not the software but instead the command that is used to extract the data. This problem has been asked before in this forum too
Can you please try and reproduce this issue on your C# layer of the HIL API to verify the bug. We have done everything on our side to confirm the bug.
This is an important issue, we want this resolved at the earliest so we can efficiently use the veristand hardware.
Message 14 of 16
(2,215 Views)
There is another issue we are facing here. Its with the download times for the STI files to the NI hardware.
For more info on this issue please go through this thread :
https://decibel.ni.com/content/message/73691#73691
Message 15 of 16
(2,215 Views)
Hi, I noticed that the ASAM HIL API for NI Veristand downloaded from https://decibel.ni.com/content/docs/DOC-29621 has an issue.
(Setup_ASAM_HIL_API_for_NI_VeriStand_v2012_v1.0.1.zip)
When installed i got the error:
Error: "StandardError: Unknown Error, Internal error in ExtractSignalValue  Could not load file or assembly 'NationalInstruments.Tdms, Version=9.1.40.204,  Culture=neutral, PublicKeyToken=dc6ad606294fc298' or one of its dependencies.  The system cannot find the file specified."
Checked the Microsoft.NET folders and the following folder was missing:
C:\Windows\Microsoft.NET\assembly\GAC_MSIL\NationalInstruments.Tdms
I then uninstalled "Setup_ASAM_HIL_API_for_NI_VeriStand_v2012_v1.0.1.zip"
And installed an earlier version that i was using on a different test bench, ( I believe it is v1.0.0 )
Now everything works fine and "C:\Windows\Microsoft.NET\assembly\GAC_MSIL\NationalInstruments.Tdms" has been installed
Please check before releasing new versions of the HILAPI.( this may be a bug )
Message 16 of 16
(2,215 Views)
